Changing scale with sliders crashes 3DView [fixed]
DJ 3pm
Post by DJ 3pm »
I know this is a beta and will be prone to crashes. I do beta testing for another software company and they have a special place for the logs. Do you want the crash logs? I'll keep posting them if you want them, otherwise I won't bother.
This crash occurred as I was changing the Scale of a fixture in the Fixture Settings window of 3D.
DJ 3pm
Re: Mac crash logs
Post by DJ 3pm »
After more troubleshooting I can duplicate this issue consistently by doing the following:
- open 3D View
- move window to fix bug documented @ viewtopic.php?f=44&t=741
- open Fixture Settings window
- select fixture from Fixtures in stage
- select Scale
- double click the text field to select value
- with text field value selected (Scale Y in this case), click anywhere on the value slider to the right
* immediate crash
Re: Mac crash logs
Thank you for the clear report.
We are able to reproduce this bug.
We will keep you informed, when available fix.
Re: [Mac] changing scale with sliders crashes 3DView
Topic moved in section 3DView, because bug is existing in V6.26 as well.
Re: Changing scale with sliders crashes 3DView
Fixed for next release.
The fix is available in the ZIP files here: http://download.thelightingcontroller.com/software/V6/
