Hi
I'm trying to make some generator movement only programs with Chauvet Trio and Chauvet 357z irc movers but the pan/tilt channel doesn't show in channels menu.
Ive tried it with 30ch and 15ch on the Trios - no joy
thx
different fixtures not working well together [fixed]
Re: different fixtures not working well together
We checked the profiles and we found an error in the IntimidatorSpot375ZIRC(15ch) model.
The fourth channel is "pan fine" instead of "tilt fine".
Please use the attached updated file.
- IntimidatorSpot375ZIRC(15ch).txt
- (2.49 KiB) Downloaded 1148 times
thx,
that works with the trio 30ch version, I've noticed the trio 30ch doc has some errors please check the 1st mode channel
here's the Manual:
https://www.chauvetdj.com/wp-content/up ... M_Rev5.pdf
Any chance you can add button in steps menu at the top that can change all fade/step buttons to step
here's the Manual:
Noted.I've noticed the trio 30ch doc has some errors please check the 1st mode channel
To do that:Any chance you can add button in steps menu at the top that can change all fade/step buttons to step
Re: different fixtures not working well together [fixed]
I mean all the channels. eg when you click said button all the dmx channels across the step menu would change to step and when I click again they would change back to fade
thx
thx
For that, select all channels (ctrl or shift + mouse click) (red check mark) and press the transition button of any of them.
