request - MIDI faders to faders in Steps
create scenes with steps
pikip72
Post by pikip72 »
il y a t'il possibilité d'utilisé les fader MIDI d'un APC mini pour contrôlé directement les fader dans Editor Steps ?
Re: request - MIDI faders to faders in Steps
Désolé mais ce n'est pas possible.
Les messages midi sont patchables soit directement sur les canaux dmx, soit pour piloter les boutons/faders dans Live.
AlfieMando
Post by AlfieMando »
Its a shame because this would make creating scenes so much simpler with a midi controller attached. I wouldn't even mind using a different midi controller from the one used in live.
I create or edit scenes at every venue and it is more fiddly using mouse and keyboard rather than a controller.
Gilles
Post by Gilles »
+ 1
Pouvez-vous SVP nous expliquer comment faire ça avec potentiomètre midi ?
https://youtu.be/I69nvGUSqcw
AlfieMando
support wrote:Pouvez-vous SVP nous expliquer comment faire ça avec potentiomètre midi ?
If you could just make the each fader bar selectable / adjustable by UP/DOWN on the keyboard atleast it would be easy enough to use a midi knob or slider to mimic up/down behaviour even via the operating system.
The options in the above video can be selected if you just drag the fader to the corresponding dmx range but the main channels that this is good for speeding up setup is x / y / focus.
Noted for the next major version.
Urs
Post by Urs »
+1
I would also welcome it if the STEP faders / channels could be controlled via midi. Programming with hardware faders is much easier than with the mouse. But it is important that the channels are individually assignable, as with the fixtures. I don't always need all channels of a device on the faders when programming.
When is a new major release planned?
Urs
Return to “Editor - Steps”
