different models of fixtures - no pan/tilt shown
jason5d
Post by jason5d »
Hi
I'm trying to make some generator movement only scenes
with Chauvet trio and robe robin 1200 movers but the pan/tilt channel doesn't show in channels menu
It appears showxpress is combining pan/tilt and ultra pan/tilt on the robin 1200 to make them not combine
any ideas for a work around? maybe alter the personality - I don't use ultra p/t on these big washes
thx
Re: different models of fixtures - no pan/tilt shown
Yes, their profiles say they both have the channels:
pan, pan_fine, tilt_tilt_fine
so Generator shows one line for this.
May be the personality file is wrong ?
jason5d
Post by jason5d »
The personality file is Robin 1200 21ch. I got you to do, can you check please
and trio 15ch.
thx
This is because Robin1200 21ch has 16bits pan/tilt channels, while Trio 15ch not (our first test was with the 30ch model).
Our software is presently not able to manage high-res pan/tilt channels with low res pan/tilt channels together.
This is noted.
In the meantime, please use the Trio in high-res pan/tilt mode.
jason5d
Post by jason5d »
using 30ch mode on the trio's worked
thx.
