Pan/Tilt reverse for a single generator scene [done]
CPSL
Post by CPSL »
I am working on programming four Intimidator Hybrid 140SR in showXpress (also have 90W LED spots and Beam 230s) and would like to know if it is possible, in the software to flip "pan" or "tilt", or both, in just one (or several, but not applicable to everything) saved generator scene? So that for instance, I can have the pan/tilt doing a clockwise circle on the left fixtures and a counterclockwise circle on the right fixtures.
I'd like to maintain the ability to have sequential, same direction chases as well, so flipping pan and/or tilt on hardware or on software program wide is not an option.
Thank you for taking the time to help!
Re: Pan/Tilt reverse in software for a single generator scen
This is possible with the: tool bar > button "Menu" > menu "Generator fixtures" > tab "Pan/Tilt reverse"
CPSL
Re: Pan/Tilt reverse for a single generator scene [done]
Post by CPSL »
Ah, yes!
Thank you so much. It works beautifully!
