Master Faders -100 to +100
TWForum
Post by TWForum »
Using ShowXpress on PC, I have setup 6 master faders set to dimmers for certain groups of lights. These faders run from the value -100 to +100. -100 is the lights fully off, 0 is the lights fully on. There is no change between 0 and +100, rendering half of the fader length useless.
I am using the software with an AKAI MPD26 that has 6 physical faders. This means that on the physical faders, the top half does nothing.
Am I missing something really obvious? Is there a way to change the software master faders to a range of 0 to +100?
Cheers
Re: Master Faders -100 to +100
The Master Fader acts proportionally, from -100% of the normal value to +100% of the normal value.
TWForum
Post by TWForum »
support wrote:The Master Fader acts proportionally, from -100% of the normal value to +100% of the normal value.
As the master faders are set to dimmers, surely there's a way to get them to go from fully off to fully on? Fully on is currently half way up the fader, so it makes fades much less smooth...?
Please use the "Sliders" for standard (non proportional) faders.
FYI: https://forum.thelightingcontroller.com ... =72&t=3647
With Master Fader, if you program the value of the channel to less than 100%, then the Master Fader section from 0 to +100% will change the value.
thorehl
Post by thorehl »
I too don't get this at all.
Master Dimmer: 0-255(dmx) = fader 0-100% (top half) ~ Under 0 has no effect on a dimmer
Speed fader: 0-whatever value = fader -100%-0 (bottom half) ~ Over 0 has no effect on speed
Thore
Controller: 2x Akai APC mini
my DIY light mixer
