[6.00] DMX addressing problem (channel - 1) [fixed]
jtorrence
Post by jtorrence »
I am using 6.0. I have several fixtures declared in my setup. It all works fine in 3D. However, my Intimidator 2.0 is configured in Showexpress with a starting address of 41. However, when I run it in real time with the fixture the DMX addresses dont correspond correctly. I had to end up setting the fixture to DMX40 for the control board channels to line up properly. DIP swith 6 and 4 ON, all others off. Is there a baseline setting somewhere that I missed ?
Allan
Re: DMX Addressing
Post by Allan »
When turned on, the value of switches 4 & 6 equals a starting address of 040, not 041. If you need the fixture to be addressed at 041, turn on switches 1, 4, & 6. Please check your settings again and let us know if there is still a problem.
I checked my software and when dips 4 & 6 are activated, ShowXpress tells me a starting address of 040. Is this not what you are getting?
Allan Reiss
Senior Product Manager
CHAUVET DJ
jtorrence
Re: DMX Addressing
Post by jtorrence »
Showexpress is set to 41. However, I had to set the fixture 40 to make it respond correctly.
kahilzinger
Re: DMX Addressing
Post by kahilzinger »
You might have a short at Switch 1.
jtorrence
Re: DMX Addressing
Post by jtorrence »
Nope. It works correctly on version 5.2.1
kahilzinger
Re: DMX Addressing
I got nothing...if you can get your hands on a DMX analyzer, you could try checking the value the box is sending.
jtorrence
Re: DMX Addressing
Post by jtorrence »
Thanks for the input..I will head out to my local Walmart and pick on up! LOL...I am getting ready to purchase another DMW box anyway(512 plus) so I will see if the problem follows the hardware. Maybe there is something weird about 6.0 and the usb cable 100. Thanks
kahilzinger
Re: DMX Addressing
I would definately go with the box over the cable. Why limit yourself? I have one at home and an SSA in the club.
As far as the DMX analyser, depending on where you are, you might be able to borrow or rent one. I am pretty good with one company who builds for the major tours so I was able to get a firmware upgrade tool for some Martin lights that saved me some money and time.
Re: DMX Addressing
Return to “Setup”
