Import show from software version 5
Frequency Asked Questions
Use the automatic light show converter "LightShow_V5_to_V6.exe": viewtopic.php?f=2&t=48
Only for those who want to know the technical side:
In order to respect "multi-users" operating systems rules, the show datas are now stored in the "home directory" folder. Please read this for more infos about the "home directory": http://en.wikipedia.org/wiki/Home_directory. Version 6.00 is able to read show files from version 5.20. However, these files must be moved to the correct folders:
- copy "fixture.ini" into folder "home_directory/TheLightingController/LightShows/default/"
- rename "fixture.ini" to "fixtures.ini", into folder "home_directory/TheLightingController/LightShows/default/"
- copy all "txt" files from folder "fixture/private/" into folder "home_directory/TheLightingController/LightShows/default/fixtures/"
- copy all "sce" files from folder "light/" into folder "home_directory/TheLightingController/LightShows/default/scenes/"
- copy "Live.ini" from folder "Live/" into folder "home_directory/TheLightingController/LightShows/default/Live/"
- copy "fixtures.ini" from folder "3DView/" into folder "home_directory/TheLightingController/LightShows/default/3DView/"
- copy "other.ini" from folder "3DView/" into folder "home_directory/TheLightingController/LightShows/default/3DView/"
The light show converter "LightShow_V5_to_V6.exe" does this automatically.
Return to “FAQ's”
