Artnet setup
control Artnet fixtures
rdreiers
Artnet setup
Post by rdreiers »
I can't find the the answer so here is the question.
I have a running configuration with a usb interface (former 19" version)
Now i want to add a artnet node and the whole universe 1:1 the same at the artnet node.
Is this possible and how should i do this.
So in the end i want the same signal at the interface as at the node.
Richard
Re: Artnet setup
Please read this to know how to proceed: https://forum.thelightingcontroller.com ... =81&t=3741
rdreiers
Re: Artnet setup
Post by rdreiers »
Shame, why not easy duplicate the interface out to artnet.
Richard
Djclub
Re: Artnet setup
Post by Djclub »
Wait what??
If i want to use all 6 universes that the software povides, i cant just connect an cat 5 cabel to the computer and connect thar cable into an enode?? That doesnt work?
I want to use only one cat 5 cabel and get 6 universes out of it and that is only possible through artnet.
If i have understand it correctly you can get 8 universes throught arnet in a single cable. If i connect through analog with car 5 cable i only get max 4 universes in a single cable
So what works?
Return to “Artnet”
