Cameo - F2FC mode 10 and 16 ch direct
Leon63
Post by Leon63 »
Can you please create a fixture for the CAMEO F2FC "10 CH HSI-CCT 16Bit Mode" and "16 CH Direct-CCT 16Bit Mode"
https://www.cameolight.com/fr/downloads ... -248088278
Is simulation 3Dview possible in this mode ?
Thanks in advance.
If you want to add to the fixtures database, I created Cameo_F2FC_Mode_4
Code: Select all
ViewType = VIEW_TYPE_COLOR_CHANGER
ViewPower = VIEW_POWER_LAMP250W
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 30
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
3DViewShape =
2DViewImage =
Channel = red
 index,0,255
Channel = green
 index,0,255
Channel = blue
 index,0,255
Channel = white
 index,0,255
Re: CAMEO F2FC mode 10 and 16 CH Direct
Hello.
The profiles are done.
They will work in 3DView, except the 10ch variant which uses HSI (hue, saturation).
And thank you for the "Cameo_F2FC_Mode_4" profile.
Leon63
Re: Cameo - F2FC mode 10 and 16 ch direct
Post by Leon63 »
Thank you so much.
