request - global xy offset
dumbfungus
Post by dumbfungus »
When declaring fixtures we can invert Pan and Tilt on the grid screen.
I propose that there should be an option to offset ALL pan and tilt values for ALL fixtures capable of pan / tilt.
For example with mobile set up, fixtures often end up mid-aligned. It would be so much easier to offset pan/tilt values with a fixed number. For example, one scanner may get a global “add 3 to all pan values” and “subtract 6 from all tilt values”
This way, after setting and wiring all fixtures, we could simply recall a known scene (or a scene made specifically for alignment). Adjust X and Y values as I described, and then the entire show looks good.
Re: Feature request: global xy offset
Yes you are right.
This will be so in the next major version of our software.
Re: request - global xy offset
You already can offset pan/tilt from the "Fixtures" grid in V9 from "offset / zoom" in the toolbar or in the context menu.
dumbfungus
Niffo wrote:You already can offset pan/tilt from the "Fixtures" grid in V9 from "offset / zoom" in the toolbar or in the context menu.
Somehow I missed this!
This will fix the problem I mentioned, where each fixture may need slight adjustment to compensate for a slightly mid aligned focus?
Return to “Editor - Fixtures”
