Problem with positioning objects
Lightray
Post by Lightray »
Hi Guys,
well once again i am having this problem in the 3d visualiser this time with the truss not staying in position, if you remember i reported the same problem with instruments not staying where they were put a while back (in which i had no reply at all from support.)
Would it be possible to put into 3d a save button to lock in the settings when you have set your stage, can't understand why there isn't one.
Re: Problem with positioning objects
Each 3D object position change in 3DView is supposed to be saved in real time.
If possible, please post a video showing the problem.
