Saving 3D fixture models
ryvanz
Post by ryvanz »
I'm working on some custom light cubes, and I was wondering if it's possible to simply save my model in the software after I've selected the dimensions, and then reimport for each instance of that fixture?
Thanks!
Re: Saving 3D fixture models
It is unfortunately not possible to import a new "colored object" in 3DView.
As workaround, you can use the "colored object" called "panel", and you can replace the software file "../YourSoftware/3DView/fixtures/color_shape/panel.obj" by your OBJ file.
