Here is a new virtual lightshow, based on the Skrillex's remix of "Levels" by Avicii: https://www.youtube.com/watch?v=VYgiSt_ZBDE
It is programmed in the same (fictional) setup from the "Blah Blah Blah" lightshow, essentially a cubic-shaped club with most of the fixture hung on horizontal trusses on the front wall. From the old post description:
The first universe is entirely dedicated to the control of 100 RGB spheres (500 channels), that I placed on the walls and ceiling of the stage. This is the first time for me using RGB spheres in such a massive way, and I'm happy with the nice "uplifting" effect they can display (used in the intro of the song).
The second universe is almost entirely dedicated (504 channels used) to manage all hanged "primary" beam fixtures on the main trusses.
The third universe is definitely the fullest, with all 512 utilised to control multiple fixtures types. In this universe are present:
- the beam fixtures located on the ground around the artist and directly above the stage;
- the lighting located in a circular truss rigged on the ceiling (that I didn't utilize in this show);
- 15 strobes
- the LED blinders
The fourth universe (at 507 channels) hosts all the washlights and the "alternate" set of beam fixtures (the ones placed in pairs on the upper side of the trusses).
In the previous "stage view" (https://youtu.be/oeZ9DDfqMMY) you can see the draft (to which I made changes in the final version) of the present lightshow.
The show is entirely timelined, I believe approximately 70 scenes are used for this project.
The most interesting part of the project clearly is the approximately 1/3 of the show with intense dubstep music and lighting. I tried to follow the details of the track as much as possible, like at 02:37. In the final "dance section" however I preferred to make extensive use of blinders and flood the audience with lights.
Hope you like it
![Sourit :)](./images/smilies/icon_e_smile.gif)
As usual, if you have any question or feedback, ask here or under the video
![Clin d’œil ;)](./images/smilies/icon_e_wink.gif)
