fade out to values 0
daan44444
Post by daan44444 »
I would like to add something to this topic (https://forum.thelightingcontroller.com ... 7&start=10). Now you are able to disable a channel on any given step, which is a very good thing.
Imagine the following scenario: you have a couple pars set with dimmer full on in blue on a seperate scene which is active in live mode. I want to make a flash button in live view which lets them snap to red and, when released, fade back to the originally set color. If the original color would be green, it would fade back to green, etc. It can be done, but you would need a seperate flash scene for each different base color.
The problem with this is, that you can disable channels, but when you hit a step where te color channels are disabled, they will snap back to the originally set color, and it can't be faded in any way.
I would like to see a feature, which allows me to select if i want to fade into the disabled channel, or snap into it. Just like you would with enabled channels (the fade or snap marker below the green, enabled fader)
daan44444
Re: Keep channels disable in some steps [fixed]
Post by daan44444 »
Bump
We have no doable (means without redoing the complete scenes play engine) solution for that.
FYI, in the coding side, switch off a scene (or channels) with a fade means create a virtual scene with the channels off, and make a fade transition to this scene.
And there is no way to do this inside a scene.
Sorry for that.
thorehl
Post by thorehl »
support:
If initial color is Blue, like daan44444 has, and he hits a Flash button with Red and it has Fade Out enebled, why can't the Fade Out option allow for Fade Out on Red, yet fading in Blue at its original value?
He'd have to have in his Red flash button active channels for Blue and Green, but at value 0 to "turn off" the current active Blue.
Thore
Controller: 2x Akai APC mini
my DIY light mixer
Please post a video, with an easy lightshow, with only one fixture with 3 only channels "RGB", and only two buttons (if we right understood), showing the problem.
And we will check again.
thorehl
Post by thorehl »
Video:
You can see the fixture dimming all channels (RGB) down to 0, then popping in the previous active BLUE. We want it to fade back the BLUE active channel from the first button (active step file). If we leave the BLUE channel (and green) disabled in the RED button, the color bump turns pink as the blue channel is currently active and not affected buy the RED color bump.
Thore
my DIY light mixer
Thank you for the video.
Understood that this remark has nothing to do with the original topic, so we moved it to a new topic in the correct section.
Yes, "fade out" always fades to values 0. The reason is the fading out scene ignores what the other running scenes are doing.
Sorry for this.
The standard using is:
- fade transitions in Steps
- no "fade out" option in Live
- page option "solo button" in Live
