Second color wheel not showing in 3d visualizer [fixed]
Lightray
Post by Lightray »
Hi all,
Wonder if anyone can help me have recently purchased Sweet light and getting to know it, the problem i am having is in the Futurelight SC 980 personalty file .
There are 2 color wheels on this fixture col wheel 2 works fine in the 3d visualizer but col wheel 1does not show any other color but white,have checked the channel and numbers to each color they are all fine as I have the Manuel to the lights, but it is baffling me why one wheel shows color but the other shows nothing but white all through the color range, have no problems at the moment writing personalities for fixtures, but this was already written in the software so it should work.
Some help or suggestions would be appreciated.
Re: Color not showing in 3d visualizer
Please post the personality file ("YourFixture.txt").
We will check it.
Lightray
Post by Lightray »
Hello, thank you for your response here's is what you have asked for, although it is the standard file in the fixtures folder of the software.
SC980.txt
The file you asked for which has been provided in the software
(1.26 KiB) Downloaded 917 times
The name of the second color channel has to be "color2".
Here is the fixed profile.
(updated in our master software's bank)
FYI, the reason of this problem is this profile is from year 2003, and on that time our 3D view was able to drive only one color wheel.
SC980.txt
(1.34 KiB) Downloaded 950 times
Lightray
Re: Second color wheel not showing in 3d visualizer [fixed]
Post by Lightray »
Thank you for very quick response and fix.
