DMX input and V9
usb to dmx (2003 - 2010)
genlitepro
DMX input and V9
Post by genlitepro »
I have just installed a "new" pc for lighting control in my church. I am running windows 10 and using V9.2.10. I have also installed the latest drivers for V9. I am running 2 universes, with the BOX on U1, and a D512 on U2 Everything works fine, except the DMX in no longer works. I have patched the dmx using the new settings in editor-fixtures, and all seems to fine, but there is no response when I move the dmx faders. any ideas on what to look for, or is the "box" just to obsolete for this feature to work?
Re: DMX IN
Yes, V9 is not able to manage the dmx inputs of this interface.
Sorry for that.
Disco's
Re: DMX input and V9
Post by Disco's »
I have installed the latest version of the software. If the DMX input of the SweetLight box is no longer working, how can we have the DMX input in the soft ?
DMX input was really useful to trigger buttons in Live section (for trad projectors)
Sorry but V9 is not able to manage the dmx inputs of this interface.
To still use them, you will need to go back an older major software version which is available here: https://forum.thelightingcontroller.com ... =85&t=4553
PS : we recommend Midi devices (like "APC Mini") to trigger buttons in "Live" section.
Disco's
Post by Disco's »
Ok, understood. Thank you for your reply.
Lpdl
Post by Lpdl »
Bonjour,je suis étonné,car j’arrive a faire fonctionner l’entrée dmx du boîtier avec la version 9 mais sous Windows 7 pro.
Ma configuration est de 1 boîtier Box et 2 boîtiers d512.
1. vous avez la version 9 de notre logiciel qui tourne sous Windows 7 pro ?
2. vous pouvez exploiter dans V9 les canaux provenant l'entrée DMX de l'interface Box ?
Pouvez-vous SVP confirmer ces deux points ?
Lpdl
Post by Lpdl »
1- oui :mrgreen:
2- oui :mrgreen:
1- Donc oui,Windows 7 pro 32bit car je le trouve très stable et très léger. La configuration est la suivante:
- Nano pc shuttle équipé d’un Intel® Pentium® Processor G2030 (3M Cache, 3.00 GHz) 8Go de ram disque dur 320 Go et une carte sd de 8Go (pour sauvegarder les shows ;) )
- 2 écrans tactiles iiyama 21"
- clavier et souris de gamer (pour le rétro éclairage)
- 1 Box et 3 D512 (donc une qui vient de fumer :evil: )
- 1 IPad mini qui sert de pads
- 1controleur Elation midicon 2
- 1 contrôleur Akai Apk20
- 1 contrôleur korg nano control
Et cerise sur le gâteau une console Dmx 8 canaux de chez Botex qui avant que je trouve la fonction à travers la Box était indépendante et ne gérait que la face en trad.( j’ai toujours gérer la face indépendamment, car en cas de plantage de l’ordinateur le spectacle peut continuer le temps de tout redémarrer.)
J’ai juste fait un inverseur (by-pass)qui me permets d’être entièrement autonome en cas de soucis (comme si il n’y avait pas de gestion par le logiciel) si non cela reste complètement transparent.
J’ai juste fait ça car je travaille souvent avec des Timeline et j’étais coincé par le fait de ne pouvoir pas utilisé la face.(je sais pas si je me suis bien expliqué :lol: )
2- donc j’ai mes 8 canaux qui sont en bleu sur la fenêtre Dmx et qui réagissent sans problème.
Je peut vous faire des photos écrans si vous le désirez.
Return to “Box”
