How to disable messages from Virtual DJ ? [fixed]
live control with Virtual DJ
Alex0243
Post by Alex0243 »
Sorry if this is answered somewhere, I was looking and couldn't find it. I'm also thinking it might be more of a virtual DJ related issue but figured I would ask here first.
When you program a song using os2l with action points, and I go to cue up the song and listen to it with the volume turned down, it will trigger any light scene it passes. Is there anyway to avoid this?
Re: Virtual DJ Cue button with os2l
main menu "Preferences" > tab "Network" > line "Virtual DJ" > uncheck the option "Enable"
Alex0243
Re: How to disable messages from Virtual DJ ? [fixed]
Post by Alex0243 »
Thats not the option I'm looking for, that disables virtual DJ cue os2l points all together.
I want it to still use cue points if the volume for the track is turned up - but not if it is turned down(silent) like when you cue up a song.
Understood.
However, in our opinion, it would make sense that the option "stop sending OS2L messages when volume is muted" comes with VDJ.
May be you could suggest that in VDJ forum ?
Return to “Virtual DJ”
