No interface control [fixed]
usb to dmx - 512 dmx channels
Raul Black
Post by Raul Black »
1-Interface 512 has 1 red (pwr) light, and another green usb. Do both have to be on for everything to be correct?
2-I don't get the moving heads and lights to work
Can it be a problem with the brand of the moving head? (beam + spot)
The pair is AMS
In standalone I get the interface images with a red cross
Re: synchronize moving heads with software
The red LED on means the usb power is ok.
The green LED blinks when the software is talking with the interface.
Do you see "Interface D512S found" in the welcome screen of the software ?
If not, you have to manually install the usb drivers (https://www.youtube.com/watch?v=trr0uqop1TQ).
Raul Black
I have managed to get the interface on the page (standalone), but it still doesn't send me a signal.
The auto start square below zone 1 is not on, and I cannot turn it on manually either.
Before going further, please answer to this important question.
Raul Black
Already be solved. I just had to go to preferences and activate the universe 1
Thank you
Well noted.
FYI, by default (when you install the software) the option "Change default DMX universe mapping" is disable, and the software always finds the interface.
Return to “D512S”
