OS2L not working on VDJ2020 [fixed]
live control with Virtual DJ
GPC
Post by GPC »
I am trying to use os2l direct with Virtual DJ 2020 and cannot make it work. I was previously using it via Apple Bonjour which did.
And set up help or information about this would be great.
Many thanks
Gary
Bob_be
Re: OS2L not working on VDJ2020
Post by Bob_be »
In VDJ, do you have the os2l option set to "Yes" and the os2lDirectIp blank?
In Showxpress, have Virtual DJ enabled, with the port 7350?
GPC
Post by GPC »
Thank you for your reply.
Yes I have tried the VirtualDJ setting you suggest.
But in the Showxpress preferences, if you enable VirtualDJ it tries (and fails) to load Apple Bonjour when the software restarts. And still doesn't receive the beats from VirtualDJ.
Bob_be
Post by Bob_be »
maybe try reinstalling Bonjour???
Have you tried Pads (in VDJ) Buttons? Does Showxpress receive the button press from VDJ?
GPC
Post by GPC »
It's supposed to work without Bonjour now.
Bob_be
Post by Bob_be »
Sorry, it's been a while since I upgraded. I couldn't remember if it used it or not.
Have you tried the Pads? Does Showxpress respond?
"Bonjour" must be installed (https://youtu.be/pC4bA3Ioy-g?t=10).
GPC
Post by GPC »
Thank you for the video link.
I was under the impression we could now link VirtualDJ directly with OS2L and not have to use Bonjour. Is this coming to ShowXpress?
So far, OSL2 needs "Bonjour".
GPC
Post by GPC »
Ok, thank you for the clarification.
Hopefully, the need for Bonjour will be addressed in a feature update.
Return to “Virtual DJ”
