I can't see each pixel in 3D
djpaul
Post by djpaul »
Same problem here with Showtec Pulse Pixel Bar 64.
I can't see the light output from each pixel in 3D. It's just one regular RGBW /Led Bar.
DMX output works perfect.
Sometime i work at home and i don't have the lights installed... so it will be helpful to have this in 3D.
Thank you!
Re: I can't see each pixel in 3D
You posted to an old V8 topic, while you are using V9, so your post have been moved to a new topic.
The "Pixels" effects are visible only in the tab "Pixels".
However, to see the Editor effects in 3DView with a multi-RGB fixture, in the window "Edit Fixture > Edit channel", you have to define the parameter "Hear number".
Please watch this for more infos: https://www.youtube.com/watch?v=cMYLzZoAfkg&
Return to “Pixels”
