All off button
create lighting scenes
jrako724
All off button
Post by jrako724 »
Is there a button that will turn all the lights off at once? I have some LED lights with a single dimmer and 2 4 channel dimmer packs but when I use a group it only controls one of the channels on the dimmer pack. How in the editor am I able to do this live? I dont want a scene setup cause we aren't using scenes. I just need to turn all the lights off and back on at current levels is this possible? Thanks
tomrbland
Re: All off button
Post by tomrbland »
I don't really understand all of your post. But if you make a scene with all the dimmer channels active but turned down this acts as a "black out" scene without effecting any of the positions/colours etc that are already there.
Does this answer your question?
jrako724
Re: All off button
Post by jrako724 »
I don't want to make a new scene if possible. We are running the lights live thru the editor and just want to turn them all off for a few minutes then back on at their current levels.
marco
Re: All off button
Post by marco »
if i understand you correct.
try the dmx on/off button in editor
tomrbland
Re: All off button
Post by tomrbland »
marco wrote:try the dmx on/off button in editor
Make sure your lights don't go in to auto mode when you do this though!
Re: All off button
It looks like things would be much easier, using application "Live".
Return to “Editor”
