Generator issue- duration
create lighting scenes
Mikael81491
Post by Mikael81491 »
When using the generator, the shortest duration currently possible is 1 second. This makes it much more difficult to program very fast chases (ie along a series of colorchangers or something like that) as you have to insert numerous points, when it would be much more efficient to be able to use a duration less than 1 second.
Re: Generator issue- duration
The purpose of Generator is to generate scenes, with several fixtures and a movement delay between these fixtures. When the scene is generated, it produces steps with duration much shorter than curve duration. That is why we can not have curves shorter than 1s.
Return to “Editor”
