Change column with for sequential lists
notslaw
Post by notslaw »
Version 9.1.9
I have three different monitors that I put sequential lists on. I have created some folder and file names for scenes that are apparently very long. On my widest screen, I can't see the end of the file name. When I want to change to a file that has the same name for all but the last characters, I can't tell which one to delete by looking at them. I have not found a way to adjust column widths manually. Is that possible?
I know that the file is always added below where I click add scene, so I know which one to delete, but if I accidentally do that 1 line too high, I can remove the one I intended to keep.
I have attached a screen shot of my widest screen to show the issue (comment field is too wide in my opinion).
Re: Change column with for sequential lists
Please post a link of the screenshot.
CaptJWH
Post by CaptJWH »
I'll second the need to adjust column width. I'm descriptive with my file names and they just dont fit, but i have tons of unneeded space in the comments area.
Basically the "Comment" column is made for these descriptions.
Its width varies with the width of the window.
Noted anyway.
