Icon availability
Nelsound
Icon availability
Post by Nelsound »
Is there something that predetermines which icons appear for any given control? For example: I see the CTO (Color temperature control) icon when I am looking for something else, but when I get to that control channel it is not there. Seems there should be a pool of icons, like an iPhone, that can be added when needed.
And just out of curiosity, when you right click in the name column as if to copy or paste, there is a "strict values" option at the bottom. What is that for?
Re: Icon availability
When there is an icon with the same name than the level/channel name, the icon is displayed.
For instance:
- in "channel", the name "pan" shows the icon "../YourSoftware/TheLightingController/editor_fixtures_icons/channel/pan.png"
- in "other", the name "pulse_open" shows the icon "../YourSoftware/TheLightingController/editor_fixtures_icons/other/pulse_open.png"
ColterCreation
Post by ColterCreation »
support wrote:When there is an icon with the same name than the level/channel name, the icon is displayed.
For instance:
I was hoping you could confirm if the latest software version (I'm on 9.2.38) on Windows 10 should still have all the icons listed in C:\Users\MyAccountName\TheLightingController\editor_fixtures_icons? I only see 3 things listed in the TheLightingController directory:
  • LightShows
  • param.ini
  • WebVersion
Could you help me find this icon pack so I can help myself when creating missing fixture personalities? Thank you!
"C:\Users\MyAccountName\TheLightingController" stores only the lightshow data.
The icons of our software are in the software folder: "C:\Programs\YourSoftware\"
Return to “Editor - Fixtures”
