Fixture is always flashing [fixed]
Carlfortin
Post by Carlfortin »
Hi. First I would like to thanks the support. I asked 2 questions and I had a fast answer and it worked. There is another one. I created 4 led can (I created some before) from scratch and example if I just slide up the red. It’s red in real life but flashing red in 3D view. Why?
Update: happens just when the strob channel is there. Even if it’s disable. Just to be present cause the problem
Re: De 3D view is not the same then real
Please post the personality file and we will check it.
Carlfortin
There it is
[file]
Carlfortin
Anybody can help me?
If the fixture is "Stands.txt", you have to rename the channel "strobe_speed" by "shutter".
Please watch the "demo_show" for more understanding (https://forum.thelightingcontroller.com ... =85&t=4556).
Carlfortin
Re: Fixture is always flashing [fixed]
Thank you a lot ! it works ! like always you're the best !
