problem with Ssa
Wille
problem with Ssa
Post by Wille »
hi i have borrowed a ssa that i will fix but i dont get it to work. The symptoms are that it cannot be saved on Ssa. sometimes when it is possible to save the X and Y movement is uneven and the color flashes or changes. on the moving head I have used.
And if I use an LED lamp then it will be the same error. So I have some questions that can help me.
1. Does a Ssa work with sweetlight version 9.1.9?
2. Is there any type of battery in Ssa that may have become bad so it does not work properly?
3. Is it for DMX speeding up to it?
Re: problem with Ssa
It is supposed* to.
*supposed because of 9 years of computer (usb) technology difference
For standalone, please use the latest fix (https://forum.thelightingcontroller.com ... f=2&t=5922).
No.
Sorry but we do not understand this question.
Wille
Post by Wille »
DMX speed is it the same today and 10 years ago?
It is 20Hz for the software channels refresh.
It is 35Hz for the dmx signal refresh of the existing dmx interfaces (D512/Remote/Rack).
It is 10Hz for the standalone channels refresh.
Wille
Post by Wille »
ok i got it working now thanks. but do you know how you can play scens on ssa without it looping?
Sorry but this is not possible.
As workaround, we suggest you to had some steps at the end of the scene.
Wille
Post by Wille »
ok. Is it possible to use 2 buttons at the same time
like controlling a moving head colors with 1 and 2 and then controlling a LEDcan colors with 3 and 4 at the same time?
Yes, this is possible.
You have to fix a different zone for buttons 1-2 and buttons 3-4.
Wille
Post by Wille »
ok thanks one more thing dose it exist somesort of user manual to the Ssa?
There is no specific manual.
If you have a question, please ask.
Return to “Ssa”
