best practice Moving different speed from point1 to point2
Tarzan4711
Post by Tarzan4711 »
best practice
Moving at different speed from point1 to point 2
Moving drives one line in 3 sec. Tilt with red. When point 2 is reached, dimmer off and the moving should go back to point 1 as fast as possible. Is that possible?
Re: best practice Moving different speed from point1 to po
You can easily do that in the tab Steps.
For each step, you can adjust:
- the duration of the step (means the speed from the previous step to the new one)
- the level and the fade mode of each channel
Tarzan4711
Thanks for the information.
But do you mean steps? At Steps, I have the problem that I can not determine the dimmer curve. Or?
The transition is linear in Steps.
For speed change in Generator, you can set different distances between the points in the curve.
Tarzan4711
I do not understand what you mean, unfortunately? how can i do that with a line?
We suggest you to watch the tutorials, in order to understand a bit more how works Generator: https://forum.thelightingcontroller.com ... =85&t=3077
