invert gobo rotate in 3D
I have added 6 Imove250s to my rig, in setting profiles my fixtures work fine in reality, however in 3D rendering, I discovered the "Gobo rotate" speed is reversed from my fixtures, ie; slow left rotate on actual fixture is rendered as fast left rotate in 3D, and vice-versa. Is it possible to invert "slow to fast values" or have an alternative "inverted" rotate left/rotate right function option in channel levels editor? I attached fixture profile for reference. Thanks!
- iMove250(16ch).txt
- (1.39 KiB) Downloaded 921 times
Re: invert gobo rotate in 3D
Sorry but this option is not existing presently.
This is noted.
This is noted.
