adj ultra bar 12 profile problem
fremontfrank
Post by fremontfrank »
I got profile loaded. but I noticed in fixture properties bottom left box it only goes to 16, not showing 20. plus when I put in dmx of 212 and close it shows 212-216 on fixture.
will not work when I use pixel.
SeekLighting
Re: adj ultra bar 12 profile problem
Post by SeekLighting »
Hey mate,
Reason for this is that the fixture has 2 channels at the end of the profile for master control (dimmer and shutter). The last pixel you can see there starts at address 16, and obviously then goes to 17 and 18. The final two channels (shutter and dimmer) cannot be controlled from pixels mode - Go into steps mode and put those channels up and then it will work
fremontfrank
thanks
did that in fixture properties, in edit panel. turned up last 2 channels. still nothing. I will try your way too.
In the window Pixels > "Fixtures properties" > "Share channels", it is possible to:
- either force the "shared channel" at a fixed value
- or disable the "shared channel" ; then these channels have to be driven by another scene
You can double check the dmx values in the window "DMX bargraph".
Return to “Pixels”
