generator manual bpm
lesley
Post by lesley »
Is there a way to make the movements made by the gernator or show creator sound controlled?
I found a way Stand alone mode> create steps file but this is verry unstable (generator project with a short duration will not save as steps file)
It would be nice if there were checkboxes in the generator in wich you could choose wich aspect was aviable for sound contoll like movement or color.
I already searched the forum.
Re: generator manual bpm
This is unfortunately not possible for this reason: https://forum.thelightingcontroller.com ... 820#p23741
lesley
Post by lesley »
support wrote:This is unfortunately not possible for this reason: https://forum.thelightingcontroller.com ... 820#p23741
This is why I state:
Everthing would stay the same with the exception that one of the aspects like movement is bpm/sound controlled as a hard setting for the project.
The power of sweetlight for me is that I can let it run in the background without making adjustments ervery few minutes, sound controll helps to achieve this.
In our opinion, the best way is to program pan/tilt movements with generator, and color changes with Steps.
