Russian language for Editor
create lighting scenes
ssk
Post by ssk »
Hello. I translate Editor into Russian language. I dont know how to add Russian language to Setup in Control board. If necessary, then I can do the translation of the rest.
I can attach .ini or .txt file here, so here it is:
[Frm_Main]
; Gadgets
Txt_Red=???????
Txt_Green=???????
Txt_Blue=?????
Txt_Pan=????????
Txt_Tilt=??????
Chk_PanLock=?????????????
Chk_TiltLock=?????????????
Chk_GroupActions=????????? ????????
; Doit rester en ordre decroissant !
Pnl_Display|1=RGB
Pnl_Display|0=????????/??????
Pnl_Channels|2=??????
Pnl_Channels|1=??????????? ??????
Pnl_Channels|0=??? ??????
Lst_Steps|-1|2=?????????????????
Lst_Steps|-1|1=???
Lst_Steps|-1|0=?????
Lst_Groups|-1|1=???????? ??????
Lst_Groups|-1|0=?????
[Editor]
; Menus
Mnt_File=????
Mnu_New=?????
Mnu_Open=???????
Mnu_Save=?????????
Mnu_SaveAs=????????? ??? ...
Mnu_Delete=???????
Mnu_Quit=?????
Mnt_Universe=DMX ????
Mnu_Universe1=DMX ???? 1
Mnu_Universe2=DMX ???? 2
Mnu_Universe3=DMX ???? 3
Mnu_Universe4=DMX ???? 4
Mnu_Universe5=DMX ???? 5
Mnu_Universe6=DMX ???? 6
Mnt_Help=??????
Mnu_Help=?????? ...
Mnu_About=? ?????????
; Tooltips
Tob_New=????? ?????
Tob_Open=??????? ?????
Tob_Save=????????? ?????
Tob_SaveAs=????????? ????? ??? ...
Tob_Delete=??????? ?????
Tob_Undo=??????
Tob_Redo=??????
Tob_Generator=?????????
Tob_DMX=DMX
Tob_3D=3D
Tob_Play=?????????
Tob_Stop=????
Btn_StepUp=?? ??????? ?????
Btn_StepDown=?? ??????? ????
Btn_StepInsert=???????? ???????
Btn_StepAdd=???????? ???????
Btn_GroupActions=Acts on all same channels
; Steps popup
Popup_StepAdd=????????
Popup_StepCut=???????
Popup_StepCopy=??????????
Popup_StepPaste=????????
Popup_StepInsert=???????
Popup_StepUp=?????
Popup_StepDown=????
; Groups popup
Popup_GroupAdd=???????? ????? ??????
Popup_GroupEdit=????????????? ????????? ??????
Popup_GroupUPdate=???????? ??????? ? ??????
Popup_GroupDelete=??????? ????????? ??????
; Misc
ImgPanTilt_Msg=???????? ?????? ? ?????????
ImgRGB_Msg=???????? ?????? ? ???????? RGB
WantToSave_Caption=?? ?????? ????????? ????? ?
WantToSave_Msg=?? ?????? ????????? ????? ?
WantToDelete_Caption=?? ???????, ??? ?????? ??????? ??? ????? ?
WantToDelete_Msg=?? ???????, ??? ?????? ??????? ??? ????? ?
Requ_Load_Scene=???????? ?????, ????? ???????
Requ_Save_Scene=???????? ????, ????? ????????? ?????
Requ_Delete_Scene=??????? ?????
ChannelValue_Caption=????????? ???????? ??????
ChannelValue_Msg=??????? ???????? ??????
RecalcStepsLength_Caption=??????????? ????????????????? ???? ????? ?
RecalcStepsLength_Msg=??????????? ????????????????? ???? ????? ?
[2DView]
Popup_ChangeFixtureImage=???????? ?????? ?????????? ???????
Popup_HideFixture=?????? ??????
Popup_SelectFixtures=??????? ????? ????
Popup_SelectAll=??????? ???
Popup_SelectEven=??????? ??????
Popup_SelectOdd=??????? ????????
Popup_SelectInvert=????????????? ?????????
Popup_SelectNone=????? ?????????
Popup_ImagesSize=?????? ????????
Popup_ImagesSize1=??????? ??????
Popup_ImagesSize2=???????? ????????
Popup_ImagesSize3=????? ????????
Popup_ShowGrid=???????? ?????
Popup_SnapToGrid=Snap to grid
Popup_ShowHiddenFixtures=?????????? ??????? ???????
Popup_ChangeBackGround=???????? ???
Popup_RemoveBackGround=??????? ???
Popup_LockFixtures=????????????? ???????
[Channels]
Popup_Disable=????????? ???? ?????
Popup_MultiDisable=????????? ????????? ??????
Popup_Copy=?????????? ???????? ????? ?????? ? ??????
Popup_MultiCopy=?????????? ???????? ????????? ??????? ? ??????
Popup_Paste=???????? ??????????? ???????? ? ???? ?????
Popup_CopyAll=?????????? ????????? ?????? ? ???? ?????
Popup_TransitionAll=?????????? "?????????" ????? ?????? ?? ??? ????
Popup_MultiTransitionAll=?????????? "?????????" ????????? ??????? ?? ??? ????
Popup_ValueAll=?????????? ???????? ????? ?????? ?? ??? ????
Popup_MultiValueAll=?????????? ???????? ????????? ??????? ?? ??? ????
Popup_ShowValues=???????? ???????? ???????
[Frm_Group]
Form_Caption=??????
Txt_GroupName=??? ??????
Txt_GroupKey=????? ??????
Cmd_Valide=???????????
[Frm_Generator]
; Gadgets
Fra_Curve=??????
Opt_Points=?????
Opt_Lines=?????
Opt_Curves=??????
Txt_Duration=?????????????????
Txt_Sec=???.
Txt_Shift=?????
Lst_Channels|-1|0=??????
[Generator]
; Popup
Popup_AddPoint=???????? ?????
Popup_DelPoint=??????? ?????
Popup_ReverseOrder=????????????? ??????? ?????
Popup_MoveSizeShape=???????/???????? ??????
Popup_LockPan=????????????? ????????
Popup_LockTilt=????????????? ??????
Popup_ExitMoveSize=????? ?? ?????? ???????/????????
; Tooltips
Tob_New=????? ??????
Tob_Open=??????? ??????
Tob_Save=????????? ??????
Tob_SaveAS=????????? ?????? ??? ...
Tob_Delete=??????? ??????
Tob_Play=?????????
Tob_Pause=?????
Tob_Stop=????
Tob_DMX=DMX
Tob_3D=3D
Tob_Generate=?????????????
Btn_NewCurve=????? ??????
Btn_LoadCurve=????????? ??????
Btn_SaveCurve=????????? ??????
Btn_DeleteCurve=??????? ??????
; Misc
WantToSave_Caption=?? ?????? ????????? ?????? ?????????? ?
WantToSave_Msg=?? ?????? ????????? ?????? ?????????? ?
WantToDelete_Caption=?? ???????, ??? ?????? ??????? ???? ?????? ?
WantToDelete_Msg=?? ???????, ??? ?????? ??????? ???? ?????? ?
WantToDeleteCurve_Caption=?? ???????, ??? ?????? ??????? ??? ?????? ?
WantToDeleteCurve_Msg=?? ???????, ??? ?????? ??????? ??? ?????? ?
Requ_Load_Project=???????? ??????, ????? ???????
Requ_Save_Project=???????? ????, ????? ????????? ??????
Requ_Delete_Project=??????? ??????
Requ_Load_Curve=???????? ??????
Requ_Save_Curve=????????? ??????
Requ_Delete_Curve=??????? ??????
[Frm_About]
Form_Caption=? ?????????
Cmd_Close=???????
Re: Russian language for Editor
Thank you very much for this job.
In fact, version 6.26beta (viewtopic.php?f=43&t=524) has already the Russian text in software. So you can use it and select the Russian flag. Please have a look at it, and let un know your mind on it.
ssk
Post by ssk »
Yes, 6.26 with Russian is very good, thank you. If you want i can correct some words and phrases for a better perception of native speakers.
Your help to improve the Russian language is welcome.
Yes, you can send us the text to change ; then we will update the master software with your text.
Return to “Editor”
