ChangeLog V9
ChangeLog V9
31 March 2026 - version 9.4.7
midi - problem with character "|" in the name of the midi device fixed
Fixtures - the window "Edit fixture > View" shows the current "Beam color"
TimeLine - color for tracks & blocks
25 february 2026 - version 9.4.5
Minor bugs fixed.
27 July 2025 - version 9.4.1
Live - process to declare the buttons linked to the Macro upgraded
24 May 2025 - version 9.4.0
Live - show the name of the master speed fader
Live - new process to declare the buttons linked to the Macro
14 April 2025 - version 9.3.23
general - new version native for macOS Silicon computers (M1, M2, ...)
hardware - supports the DMX interface "D1024W" in USB and WIFI modes
Live - Midi trigger for tabs
19 February 2025 - version 9.3.21
MacOS - Midi decoding problem when two notes are received at exactly the same time fixed
20 January 2025 - version 9.3.20
minor problems reported in the forum fixed
2 August 2024 - version 9.3.17
version 9.3.17 for MacOS and version 9.3.16 for Windows
TimeLine - sync accuracy improved
Communication with external programs improved
Midi - the message "NoteOff" sets the level of the DMX channel to 0
Pixels - manages the BRG (blue, red, green) LED channel order
minor problems fixed
27 June 2023 - version 9.3.8
MacOS - first BETA version native for M1 & M2 computers
MacOS - correct centering of 3DView on Retina screens
Windows - DPI Scaling management
Midi - Behringer X-Touch Midi support
Os2l - "Do not use Apple/Bonjour" option for OS2L/VirtualDJ
Midi - Midi-in stability improvement
MacOS - better stability with Live_Mobile
ScreenControl - redesign of the display of images
27 July 2022 - version 9.2.38
general - working with GRB LEDs
general - Czech language added
Live - BPM timer more accurate
Live - working with new OS2L function "os2l_button 'Scene1' & os2l_button 'Scene2'
Live - scene buttons control with flash buttons of interface Rack1024
Live - higher resolution for pictures in scene buttons
TimeLine - BPM/Beat speed features
8 December 2020 - version 9.2.23
MacOS - meets the new "Big Sur" security app rules
Windows - problems fixed with some 32bits Operating System
Live - new Beat/BPM option to play scenes (https://www.youtube.com/watch?v=-iR_WDY-WuM)
Live - nb max tabs increased to 20
Live - new option "Live > Buttons settings > Miscellaneous > Darker button image at 'off'state"
TimeLine - nb max timelines increased to 20
15 January 2020 - version 9.2.10
general - mark on button "Save" to remind recent change has been done
general - number max of heads for one fixture increased from 10 to 20
MacOS Catalina - signature problem fixed
MacOS Catalina - Codecs problem fixed
Steps - new option "Enable/Disable channels on all steps"
Steps - multi channels enter values with keyboard (type for example "10|20|255")
Generator - new popup window to enter pan/tilt, RGB and time with keyboard
Live - new option "Duplicate page"
3 June 2019 - version 9.2.3
Fixtures - global offset for pan&tilt
Live - options 1/2, 1/4, 1/8, 1/16, 1/32, 2/1, 4/1 for BPM and Beat
Live - option "Disable" for buttons
Live - option "random play" for buttons
minor bugs fixed
20 March 2019 - version 9.1.15
Live - option "Never in Macro" for buttons
Live - option to display 6 boards
minor bugs fixed
19 November 2018 - version 9.1.9
manual - upgraded for versions 9.1.5
all - option "Not used in Lightshow Creator" for groups
Lightshow Creator - show the slider "shift" in the generated buttons (for Generator scenes)
Live - new dropdown list for pages
Live - options "Hide BPM section"
minor bugs fixed
17 September 2018 - version 9.1.00
Windows - 32bits & 64bits
MacOS - 64bits
all - dark skin
all - lightshow creator
all - multi pan/tilt management
all - menu function "New lightshow" opens the new lightshow
Fixtures - fixture shape setting for 3DView (and saved in the personality file)
Fixtures - the window "Edit fixture" has now two tabs
Fixtures - Edit fixture - option "not used in LightShow Creator" for channels & levels
Editor - the mouse wheel moves the vertical faders for channels (use the key "shift" for fine adjustment)
Generator - individual pan&tilt offsets&zoom
Generator - fan pan / tilt
Live - slider "shift"
Live - BPM and Beat
Live - Virtual DJ
Live - rotary encoder wheel (endless) for the Akai APC devices
Live - individual fade in/out time for buttons
Live - "Midi out" learn
Live - "Fade in/out" acts on pan/tilt channels
Live - the mouse wheel moves the Master Faders (use the key "shift" for fine adjustment)
TimeLine - individual fade in/out time for blocks
Sequential List - faster project loading
Sequential List - functions "copy/paste" line
3DView - new 3D engine (OpenGL 3.2+)
3DView - objects with texture
3DView - improved windows "Objects/Fixtures setting"
3DView - multi-selection for objects setting (orientation, scale, ...)
3DView - function "Change 3D object"
3DView - "pulse_close/open" works for channels "shutter" and "iris"
Hardware - instantaneous interface usb unplug / replug working
Hardware - the usb interface can be plugged and used after the program is running
