DMX Addressing issue (9/14 channels mode)
478Ministries
Post by 478Ministries »
Hi, i work with a church group and we originally had someone else set our lights up in 6 channel mode... later we changed them to 14 channel mode. Now, however, i can only get the first mover to work. i am assuming that it is because mover 1 has the same dmx channel address as it did in 6 channel mode because it is starting from the same place, whereas movers 2-6 are now starting on different channels and thus have new dmx addresses. My problem is that i don't know how to tell the physical lights what their new address is... the user manual says that mover 2 needs to have its dip switches set to 2on, 3on and 6on, the rest too off... the same with 3-6 just each with their own numbers on and off... So, how do i tell the actual lights what their new address should be?
appreciate any help!
~adam
marco
Re: DMX Addressing issue
Post by marco »
hi
in the software you already change the adresses?
or only on the mover?
you also change in the mover the 6channel/14channel mode?
The manual only shows an example
in the software in setup you can see the dipswitch setting adress.
the movers should have te same setting/adress as the in software
with the software we can help, with the movers u need to change them yourself
grtzz marco
In the software side, you can change dmx addressing here: ControlBoard > Setup > dmx addressing
For the fixture, the dip switch drawing is just for help. It is possible that the fixture requires other setting. So we can not help more for the fixture setting (this forum is exclusively for the software & dmx interfaces).
Return to “Setup”
