OS2L button names must be in lower case
live control with Virtual DJ
Tulsadj
Post by Tulsadj »
I just loaded v9 today, and I'm testing out the os2l commands in VDJ.
I've noticed that the buttons in Live must be in lowercase to work. If I have a button named "Blue", the os2l_button 'Blue' command will not activate it, but if I rename the button to be "blue" and then change the command to os2l_button 'blue' it does work.
Is there a way to fix this, or will I have to go rename all my buttons to lowercase that have upper case?
Testing using Windows 10 (1803), VirtualDJ v8.3 b4592 32 and 64 bit versions, ShowXpress 64bit v9.1.0 - 180912
Re: Virtual DJ OS2L button names must be in lower case
We are not able to fix that problem.
The "Virtual DJ" os2l command (that our software receives) transforms all capital letters to lowercase letters.
Only "Virtual DJ" is able to fix that problem.
They are aware of this problem and they told us: "it's already in the pipe to be looked".
So we suppose the next "Virtual DJ" software version will fix that problem.
Tulsadj
Re: OS2L button names must be in lower case
Post by Tulsadj »
Ok, Thank You!
Return to “Virtual DJ”
