Saving in a scene format for speed control in Live [fixed]
Focu
Post by Focu »
Hi. It would be nice if our program was able to save in the format of the scene. In the live tab we could control the speed.
Re: Saving the generator in a scene format
In Live V8 and more, it is possible to control the speed of the Generator scenes.
Focu
Re: Saving in a scene format for speed control in Live [fixe
Post by Focu »
You can speed, but you can not control the smooth transition from one scene to another. My heads will still go to the zero point and only from there they will start their movement
In Live V9, the transition from one Generator scene to another one, with the "fade" options active, is smoothed.
https://forum.thelightingcontroller.com ... f=2&t=5789
Focu
Post by Focu »
yes, but apparently you misunderstood me. When I switch from stage to stage, my head goes to a certain point and then just begins to draw motion. if I use not the format of the scene but the format of the generator, then my heads go crazy, become sharply in some sort of definite the point and the motion begin to move. I want my instruments from the stage with one step to smoothly move into motion with the speed of the speed fader. if I activate the file button of the generator then this does not happen
V9 is supposed to be ok for that.
Anyway, if not ok for you, you can sill use that as well: https://forum.thelightingcontroller.com ... =70&t=4367
Focu
Post by Focu »
support wrote:V9 is supposed to be ok for that.
yes, but what if I have 30 movements? it will take a lot of time
