Double Headed Fixtures
Post by Pink LD »
I have 6 double headed LED wash fixtures that have infinite tilt and up to 540 Pan. I programmed them mostly in the office and onsite at gigs but is it likely that 3D could support this type of fixture?
Re: Double Headed Fixtures
Multi-heads are supported, but not the infinite pan/tilt.
Post by Pink LD »
Not Multi head but a fixture with 2 emitters on the same head, so if I pointed the "front" beam to the sky, the "back" beam would be pointed at the floor.
Understood.
Sorry but 3DView V9 is not able to manage such fixture.
Post by Pink LD »
I made the 2nd RGBW as a 2nd head, then in 3D I put them right on top of my other fixtures. Now depending on their orientation I can mimic X but not Y, or Y but not X. Still I can now at least see in 3D when the 2nd side of the head is on. If I could reverse the Pan or Tilt on the 2nd head I could fully simulate my fixtures.
Cablecr69
Post by Cablecr69 »
I Have the same issue with a beam on one side and a wash on the other....i too put them togther but certain positions don't work but being able to reverse pan/tilt on individual heads would work.
