The title bar scroll menu is outside of my screen [fixed]
Hoofdsoos
Post by Hoofdsoos »
Hi
simply, i cant reach preferences, the menu button is outside my screen, and live is locked.
ive tried to ad another monitor but this didnt work either.
is there any way to reach it (scrolling with the tab button doesnt work either)?
Re: Cant reach preferences
All applications remember the window size&position before closing. So the lightshow should have been used in another computer configuration, with other monitors. We will check this problem. In the meantime, you can do this:
- ControlBoard > Settings > open lightshows folder
- open "../LightShows/YourPersonalShow/Live/Live.ini"
- in "Live.ini", delete the line "Frm_Main = ...|...|...|...|."
- save and close "live.ini"
Next time you will open Live, it will be located in center of main monitor.
Caution: modifying "live.ini" can potentially damage your lightshow. We strongly suggest you to make a backup of your lightshow, before doing this operation.
Hoofdsoos
Post by Hoofdsoos »
it worked, thanks
Return to “General”
