Showtec - Shark Combi Spot One
marco
Post by marco »
i made the 20channel for this fixture
just wondering the first dimmer,shutter and rgbw color mixing dont work in 3d. is there a way to make this work (in 3d)?
its only the spot related dimmer,shutter and color that show up in 3d
or should i remove the dimmer and shutter in the profile?
Gr Marco
shark combi one 20ch.txt
(2.05 KiB) Downloaded 827 times
Re: Showtec - Shark Combi Spot One
marco
Post by marco »
hi
still doesn't work correct in 3d
if i raise the dimmer1 (ch6) and use ch 8-9-10 or 11) nothing happens (no light)
if i raise the dimmer2 (ch14) and set colorwheel2 to red (ch16) than i can see the ch8-9-10-11 change the color,
de shutter (ch7) always works so for the channels with , , 1 and , , 2
btw im using version 8.2.28 171113
is this the same if U try it?
so far thanks for the help
marco
Post by marco »
tryed in in v9 beta
everything works fine
SeekLighting
Post by SeekLighting »
Hi Marco,
Yes, version 9 allows for these multi-head style fixtures. Previously this was not supported, hence why it wouldn't work for you in Version 8. Glad you have it working now! :)
