Order of fixtures display, in the curve
thorehl
Post by thorehl »
If I change the order of fixtures for the Pan/Tilt channels, from 1, 2, 3, 4 to 1, 3, 2, 4 the main veiwing area reflects this. Then, if I switch to the RGB channels, the main veiwing area says 1, 2, 3, 4 but the fixtures are color changing in the 1, 3, 2, 4 order.
Thore
Controller: 2x Akai APC mini
my DIY light mixer
Re: Fixture Order - V9 beta
With the popup menu in the curve section, it is possible to select "Show fixtures name":
- when selected, the names of the fixtures are displayed in the correct order
- when no selected, the software shows only numbers which are not linked to the real fixtures
PS: no change since V8 for that.
