Feature Request - Regarding Master Faders
ryvanz
Post by ryvanz »
I've noticed the following conditions when using the master fader for any given dimmer:
1. When Master Fader is at 0%, the dimmer on a corresponding fixture acts as normal
2. When Master Fader is at 100%, the dimmer on a corresponding fixture reaches maximum at 50% fader throw
3. When Master Fader is at -100%, the dimmer on a corresponding fixture does nothing, and is effectively zero
Would it be possible, instead of having condition #2, to have the result between the master fader and the fixture dimmer be cumulative, since it's not possible to be brighter than 100%. Ie if master fader is 50% and the fixture dimmer is 50%, then the resulting brightness should be 25% of total brightness. When master fader is at 90% and the fixture dimmer is at 90%, resulting brightness should be 81%. When both are at 100, resulting brightness should be 100.
I hope this made sense. Is it possible to make that change?
Re: Feature Request - Regarding Master Faders
Changing that will require a big consultation of different users, because it depends of how you program your scenes.
We could see that only after V9 will be online and stable.
