Chauvet colorband H9 usb (23ch)
Brett
Post by Brett »
Can I please request a pixel profile for the colorband H9 usb 23channel fixture please.
I watched the videos but can't seem to get it to play on fixture.
I have attached the screen shot of how I thought it might have to be done.
Sorry guys I tried.
A profile would be great thanks.
Starting address is 142.
When I hit play it doesn't seem to play on the fixture, the dmx icon in the corner is on also cheers.
Brett Rutledge
brettrutledge82@yahoo.com.au
SeekLighting
Re: Chauvet colorband H9 usb (23ch)
Post by SeekLighting »
Hey mate,
You don't need a fixture profile, you've created that just fine.
The reason you aren't getting any light to display on your fixtures here is that this fixture has a master dimmer channel (channel 22) which needs to be up to display any colour using the RGBWAUV channels that Pixels controls.
To turn this channel on and make your fixtures work, create a one step scene in Steps mode that just has your dimmer channel on, import that into Live mode and turn it on. Then your pixels scenes should work with this fixture.
Regards,
Tim H
Brett
Post by Brett »
Thanks Tim appreciate it mate I'll give it a go.
In the window "Shared channels" (click on "Edit" in the "Fixture properties"), you can also set the behaviour of these channels in Live (override or not).
Return to “Pixels”
