Missing the horizontal bar with "level" icons [fixed]
create scenes with steps
trc Lighting
Post by trc Lighting »
Hello All,
I am trying to figure out what I am doing wrong. I have been toying with ShowXpress for a week or so and am working my way through the tutorials. I have come to the section about palettes (which interests me greatly) but cannot proceed because my screen differs to those on the tutorial. I have downloaded the tutorial files and am using them for the lesson. However, above each of the sliders for the lights I do not have the black box available where you select the palettes, just a grey area with the value displayed (0-255).
Can some one tell me what I need to do to get that option available. I have the latest version of ShowXpress and am running it on a Mac, blind without lights hooked up.
[image]
Re: Missing Box
The horizontal section showing the levels ("black box") is visible only when there is enough vertical room.
If you increase the vertical size of the dimmers section (with the small grey dot above the name of the fixture), you should be able to see it.
If not, you can hide the MacOS dock and increase the vertical size of the software window.
trc Lighting
Re: Missing the horizontal bar with "level" icons [fixed]
That totally worked! Perfect, thanks
Return to “Editor - Steps”
