Martin - MAC Encore Wash
SeekLighting
Post by SeekLighting »
Hi Support,
Could you please create the fixture profile for the following fixture? The information required can be found on page 21-24 of the manual
https://www.martin.com/Martin.Download. ... h_EN_B.pdf
Regards,
Tim H
SeekLighting
Re: [Request] Martin MAC Encore Wash
Hi Support,
Please find attached my completed fixture profile for the Martin MAC Encore Wash. The control channels are particularly difficult but I tried to follow convention as best as possible.
Regards,
Tim H
Martin MAC Encore Wash.txt
(7.52 KiB) Downloaded 870 times
Thank you.
Yes this brand is not easy.
Some tricks to save time.
Trick1
In the channel "color", we suggest you to declare only the "stepped scrolling" colors, and to put the level "index" for the "continuous srolling" colors.
And you can also put the same first/last values for the fixed colors (blue, green, ...). This gives for this fixture:
  • open,0,0
    index,1,160
    blue,162,162
    green,165,165
Trick2
In the channel "FX Synchronization", there are levels "Offset shift xx degrees" every 10 degrees from 10 to 350 degrees. They can be replaced by one level "offset from 10 to 350 degrees" with the first/last dmx values 1/35.
Another thing to know: the character "," is not allowed in the level's names.
Added in the software's bank.
