Chauvet - Intimidator 375 IRC
SeekLighting
Post by SeekLighting »
Hi Support,
The current fixture profile is incorrect (colour wheel, gobo wheel, fine tilt). Please see the manual below and correct:
https://www.chauvetdj.com/wp-content/up ... ML6_WO.pdf
Regards,
Tim H
SeekLighting
Re: [Request] Chauvet Intimidator 375 IRC
Hi Support,
I have corrected this fixture profile based on the values in the manual provided. I have also added in the gobos for 3D View. Please find the file attached.
Regards,
Tim H
Chauvet Intimidator Spot 375Z IRC (15ch).txt
(2.65 KiB) Downloaded 767 times
Thank you for this new profile.
It has been added in our database.
Please check the attached profile.
We changed a few names of levels, in order to match more with future missing icons for levels.
We also removed the level when there is only one level in the channel.
If you could keep the same names in your next personality files, that would be great.
Chauvet Intimidator Spot 375Z IRC (15ch) (TimH).txt
(2.23 KiB) Downloaded 766 times
SeekLighting
Re: Chauvet - Intimidator 375 IRC
Noted. Thanks Support, I'll try match as best as possible. The control channels are tricky!
Regards,
Tim H
