[Request] Play Multiple Sequential Lists at once
SeekLighting
Post by SeekLighting »
Hi Support,
Currently you only have the ability to play one Sequential List at a time. It would be great to be able to play multiple Sequential Lists at once. Here's how:
http://credo.az/wp-content/uploads/2013 ... 00x400.jpg
Have a new tab in Live Mode. On this tab, you've got a layout much like what you see in that image above. Each fader represents one slot where you can add a Sequential List file. The Fader usually controls the intensity channels of all fixtures in the sequential list file, but it would be nice to be able to customise this. The buttons above are for GO, PAUSE and GO BACK. The button below the fader is to FLASH all the intensity channels of all the fixtures in the Sequential List file on and off (but again it would be nice to be able to customise this).
If you added this function, users of other more conventional lighting desks (Hog, GrandMA, Chamsys, Clarity, Martin M Series, etc.) would be MUCH more inclined to use your software, and would have a much more familiar interface to work with. It also allows you to play multiple Sequential Lists at once which is a MASSIVE plus.
The ability to customise the number of list faders, and the ability to be able to MIDI map the fader and buttons to a physical controller is a must obviously.
I do not believe this playback system is proprietary as it exists in almost every professional lighting console and software and is almost exactly the same.
Let me know if you think this would be something you would implement.
Regards,
Tim H
Re: [Request] Play Multiple Sequential Lists at once
