How to "manually" change the current lightshow
In case of corrupted lightshow and the software crashes at start, you can manually force the software to not load the corrupted lightshow at start. To do that:
- open the folder "../home_directory/TheLightingController/"
- make a copy of the file "param.ini" (just to keep an original backup)
- edit the file "param.ini" with a notepad
- find the line "PROJECT = " and delete it
- save the file and close the notepad
Next time you will start the software, it will open (or create) the lightshow "default".
In case of your corrupted lightshow is "default":
- open the folder "../home_directory/TheLightingController/LightShows/"
- change the name of the folder "default" (the name of the folder is the name of the lightshow).
