receiving mulitple midi notes in one time line?
djjer
Post by djjer »
I built an hour lighting show for a companies trade show booth for this weekend. They are using Q-lab to send me a midi note to start the timeline. Since we are not running the audio or video in Showxpress we want to have a fail safe option if we need to resync the timeline to the track and video again.
For the show to run for an hour straight we understand that it might get off even a little bit which can make a huge difference with lighting cues. Can we set an additional midi not or cue about 15 minutes in, 30 minutes, and 40 minutes? Is that what time stamp does, because I can seem to see why we would need time stamp.
Please let me know so I can make sure I take care of my clients worries. Thank you so much!!
Re: receiving mulitple midi notes in one time line?
We suggest you to:
- split the big timeline in several smaller timelines
- trigger them with butons in "Live buttons"
- trgger the buttons with midi messages
djjer
Post by djjer »
The only problem is there is a delay from the time you trigger the button "timeline" because it has to load the entire time line which sometimes takes 4 seconds but it isn't consistent. Thoughts?
JohnRichards
Post by JohnRichards »
My experience is that the delay in loading the timeline only occurs if you have the waveform display on.
John
Luc Henrion
Post by Luc Henrion »
If you're not using audio or video files in the timeline, it would be possible to use live buttons only instead of a timeline or is it too complicated for your show ? I don't experience any delay with live buttons triggered via MIDI.
djjer
Post by djjer »
The show we have programmed is very complex and has multiple layers. I will be running it without the audio file since Qlab will be playing the audio and video files separate. There is no way to build the show in steps etc. We are using about ten layers of timeline with very detailed cues and chases from generator.
Please uncheck the option main menu "Preferences" > tab "Main" > option "Do not preload Live scenes", and let us know the result.
BTW, if possible, please post a link to download your lightshow (https://forum.thelightingcontroller.com ... ?f=3&t=168). We will check it.
djjer
Post by djjer »
I am sending the files via email right now.
Thanks and please keep me posted. I did try to check the "don't preload in Live" but that didn't seem to make any difference.
We need your complete lightshow.
Please read this to know how to proceed: https://forum.thelightingcontroller.com ... ?f=3&t=168
Return to “Live - TimeLine”
