3D not opening in window
sound crew
Post by sound crew »
I'm new to DMX and have went through the first three training videos numerous times. Software is loaded, 512 box with driver loaded. When I click on 3d view the icon pops up in the task bar but when you click it , it doesn't expand/open. It does go to a different shade like it is open , but nothing. I have looked for it to see if it is hidden. I have uninstalled and re-installed 3 times. This is all on a new Lenovo Laptop I7, 16 gig ram 512 ssd. Only other software on it is Traktor Pro 2. Please help... :(
Re: 3D not opening in window
It might be outside of your screen resolution (may be you changed monitors ?).
Please try this:
- close the window 3DView
- open the file "../YourLightshow/3DView/3dview.ini" with a notepad application
- delete the line starting with "Frm_Main ="
- save the file and close it
This will reset the location of the 3DView window. Then you should be able to see it again.
