hello,
i have 2 shotec compact par (11ch made) as a light source in my show and they work fine trough dmx but wen in put them in my 3d viewer i cant get any sort of light out of them.
i have also put the one in the fixture bank but that wont work too.
i will put a screen online so you can see
[image]
no light output on 3d view [fixed]
requestedaxe482
- compaqpar7q4(6ch).txt
- (413 Bytes) Downloaded 996 times
- Showtex compact par 7q4 (11ch my own made fixture).txt
- (610 Bytes) Downloaded 948 times
requestedaxe482
Re: no light output on 3d view
**update**
my other light's do work including a other par i made!!
SeekLighting
Hey mate,
There's a problem with your fixture profile. On your second channel (your shutter channel) you have DMX value of 0 to be "closed". This means with that second channel on 0, no light will come out of the fixture in 3D view, because it thinks there is a shutter in front of the lens!
To correct this, edit your fixture profile so that the 0 value of Channel 2 is "open"
Regards,
Tim H
Regards,
Tim H
Yes.
Please replace your files by these ones, and it should work.
- (608 Bytes) Downloaded 969 times
- (411 Bytes) Downloaded 939 times
